Hi Den,
das Teil hab' ich schon mal gesehen... und zwar bei Tim Audio. Ich vermute, daß beide Serien vom gleichen Hersteller 'XiangSheng' stammen. Nur ist bei dem die 'Music Angel' Reihe anscheinend die schöner klingende Top-Line!
http://www.timaudio.com/photo.asp?classid=33
Ich finde, man sieht das auf den ersten Blick an der Stromversorgung des amps, beim MA 2 separate Trafos, also insgesamt 4 'Töpfe'!
http://www.yogoo.com/xd800.htm
Hab' den chinesischen Text gerade mal ins Englische übersetzen lassen, um Dir den Mund schon mal wässrig zu machen, he he...
"Music Angel XD800MKIII:
We produce the gallbladder machine, by the finest good manufacture craft, the best quality goods part, the most reasonable price, the invincible 声价 ratio, causes us to be proud also is our objective. This KT88 gallbladder machine represents our company 推挽 machine kind of most high level, the standard connection outputs 70W, dynamic is swift and fierce, the sound musical sense supreme is invincible, can let the majority England domestic product transistor machine bow the head professes allegiance, the triode connection outputs 35w, has exquisitely, most with the stomach, most likes 单端 machine the kind of timbre, may say perfectly does not have the flaw. Matches arrogantly, 贵气 the aristocrat 2.5 sound boxes, the composition illusion 5000 Yuan combinations, have far to HI - END look your sound source standard has high. In the entire trial manufacturing process, once and the domestic overseas very many brands extremely high price position transistor machine, the gallbladder machine carried on the comparison, only could let it machine host shake the head sighs is mad, had not met the true match. Certainly, our also sincerity hopes one day, the domestic gallbladder machine famous factory produces one can surmount this XD the -800MK III gallbladder machine, moves towards the world for the Chinese sound, contributes oneself one strength. The power 2×65w (standard) 2×30W (triode) the frequency makes a sound 7HZ-70CKcHcZ-3db the signal to noise ratio 95db voltage amplification 12AT7×2 impetus 12AU7×2".
© XiangSheng, yogoo.com, Google
Also ich denke, Du hast hervorragend gewählt. Mein Tipp zur Röhrenbestückung Deines MA:
Nachdem ich über 1 Jahr verschiedenste KT88 gehört habe, finde ich die KT88 EH vom Klang her am schönsten. Keine bringt den Baß so hart und trocken, wenn die Aufnahme es verlangt. Sehr dickes Glas, hervorragend verarbeitet. Kann ich also nur wärmstens empfehlen. Allerdings solltest Du wohl auch unbedingt die neue TungSol 6550 reissue probieren. Hab' sie nicht gehört, aber viele hier im Forum halten sie offenkundig für die am besten klingende. Und natürlich die China Vorstufen Röhren gegen anderes zu wechseln. Probier' mal Ei aus! Ich finde die phantastisch. Gibt's hervorragend selektiert bei BTB:
hxxp://
www.btb-elektronik.de/de/vorstufen_roehren.html
Henning
