Suche Reduce Categories v1.1.0
Diskussionen, die in keine Kategorie fallen und trotzdem wichtig sind
Gesperrt
Admin II
SysAdmin
Beitrag von Admin II »
durch einen Festplattencrash habe ich leider die Files einer Modifikation für unser Board verloren.
Hierbei handelt es sich um den
für phpBB 2.0.xx
Ich hab mir Heute schon einen abgesucht, jede Menge Hinweise aber keinen Download. Falls also jemand den Mod haben sollte bitte durchreichen.
Danke
Worm
Beitrag von Worm »
ich finde auch keinen Download, aber ich hab zumindest einen Quelltext gefunden:
## Mod Name: reduce_categories_v1_1_0.txt
## Mod Date: 2002-06-17
## Mod Title: Reduce Categories
## Mod Version: 1.1.0
## for phpBB Version: 2.0.1
## Author: Matthias C. Hormann <matthias@hormann-online.net>
## Description: some_description_goes_here
## Description: This mod allows persistent folding up (reducing) of
## categories on the main page to help users keep
## an overview on larger boards. It also changes the
## "view category" logic so that if you click on the
## cat title it will instead reduce/expand this category's
## view (as opposed to temporarily expanding this
## category and reducing all others).
## The MOD uses cookies to remember user's preferences,
## so cookies should be enabled in the user's browser.
## Categories that should be reduced by default (i.e.,
## before the user has probably chosen otherwise) can
## be set by beginning the category name with the string ":-:",
## i.e. ":-:Category reduced by default".
## Installation Level: Easy
## Installation Time: 5 Minutes
## Files To Edit: 4 (5)
## index.php
## The following need to be modified for every TEMPLATE you are using:
## templates/subSilver/subSilver.cfg
## templates/subSilver/index_body.tpl
## The following need to be modified for every LANGUAGE you are supporting:
## language/lang_english/lang_main.php
## language/lang_german/lang_main.php
## Included Files: 2
## templates/subSilver/images/icon_minus.gif
## templates/subSilver/images/icon_plus.gif
## For Security Purposes, This MOD Cannot Be Posted Or Added At Any Non-Official phpBB Site
## Author Note:
## o This mod is EasyMod v0.4alpha compatible.
## o Best viewed when your editor's tab size is set to 4.
## Change Log:
## o v1.1.0
## - Initial Release to the public, after several optimizations.
## - Includes English as well as German language mod.
## o v1.0.0
## - Internal release for testing only.
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ COPY ]------------------------------------------
#-----[ OPEN ]------------------------------------------
index.php
#-----[ FIND ]------------------------------------------
// End session management
#-----[ AFTER, ADD ]------------------------------------------
// MOD: Reduce Categories v1.1.0
if ( isset($HTTP_GET_VARS[POST_CAT_URL.'_expand']) )
// set cookie; expires in 1 year from now
setcookie($board_config['cookie_name'] . '_' . POST_CAT_URL . '_' . $HTTP_GET_VARS[POST_CAT_URL.'_expand'] . '_reduced', '0', (time() + 31536000), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
$header_location = ( @preg_match("/Microsoft|WebSTAR|Xitami/", getenv("SERVER_SOFTWARE")) ) ? "Refresh: 0; URL=" : "Location: ";
header($header_location . append_sid("index.$phpEx"));
if ( isset($HTTP_GET_VARS[POST_CAT_URL.'_reduce']) )
setcookie($board_config['cookie_name'] . '_' . POST_CAT_URL . '_' . $HTTP_GET_VARS[POST_CAT_URL.'_reduce'] . '_reduced', '1', (time() + 31536000), $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
// MOD: -END-
$template->assign_block_vars('catrow', array(
'CAT_ID' => $cat_id,
'CAT_DESC' => $category_rows[$i]['cat_title'],
'U_VIEWCAT' => append_sid("index.$phpEx?" . POST_CAT_URL . "=$cat_id"))
#-----[ REPLACE WITH ]------------------------------------------
$reduce_by_default = ':-:'; // this string first in a category title denotices "reduce by default"
// check if this category should be reduced by default
if (substr($category_rows[$i]['cat_title'], 0, strlen($reduce_by_default)) == $reduce_by_default)
$cat_title = ltrim(substr($category_rows[$i]['cat_title'], strlen($reduce_by_default)));
$reduce_cat[$cat_id] = 1;
else
$cat_title = $category_rows[$i]['cat_title'];
$reduce_cat[$cat_id] = 0;
// now check if cookie set; use if so
if (isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_' . POST_CAT_URL . '_' . $cat_id . '_reduced']))
$reduce_cat[$cat_id] = $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_' . POST_CAT_URL . '_' . $cat_id . '_reduced'];
// build +/- icon link and ALT text
if ($reduce_cat[$cat_id] == 1)
$cat_reduced_url = append_sid("index.$phpEx?".POST_CAT_URL."_expand=$cat_id");
$cat_reduced_img = '<a href="' . $cat_reduced_url . '"><img src="' . $images['icon_plus'] . '" alt="' . $lang['Expand_this_category'] . '" title="' . $lang['Expand_this_category'] . '" border=0></a>';
else
$cat_reduced_url = append_sid("index.$phpEx?".POST_CAT_URL."_reduce=$cat_id");
$cat_reduced_img = '<a href="' . $cat_reduced_url . '"><img src="' . $images['icon_minus'] . '" alt="' . $lang['Reduce_this_category'] . '" title="' . $lang['Reduce_this_category'] . '" border=0></a>';
$template->assign_block_vars("catrow", array(
'CAT_DESC' => $cat_title,
'CAT_REDUCED_IMG' => $cat_reduced_img,
'U_CAT_REDUCED' => $cat_reduced_url,
continue;
// MOD: -END-
// Vote graphic length defines the maximum length of a vote result
#-----[ BEFORE, ADD ]------------------------------------------
$images['icon_minus'] = "$current_template_images/icon_minus.gif";
$images['icon_plus'] = "$current_template_images/icon_plus.gif";
// MOD: -END-
<td class="catLeft" colspan="2" height="28"><span class="cattitle"><a href="{catrow.U_VIEWCAT}" class="cattitle">{catrow.CAT_DESC}</a></span></td>
<!-- MOD: Reduce Categories v1.1.0 -->
<td class="catLeft" colspan="2" height="28"><span class="cattitle">{catrow.CAT_REDUCED_IMG}&nbsp;<a href="{catrow.U_CAT_REDUCED}" class="cattitle">{catrow.CAT_DESC}</a></span></td>
<!-- MOD: -END- -->
# (ENGLISH)
// That's all Folks!
$lang['Expand_this_category'] = 'Expand this category';
$lang['Reduce_this_category'] = 'Reduce this category';
// MOD: -END-
# (GERMAN)
$lang['Expand_this_category'] = 'Diese Kategorie expandieren';
$lang['Reduce_this_category'] = 'Diese Kategorie reduzieren';
// MOD: -END-
#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
# EoM
Markus
Admin II
SysAdmin
Markus,
tausend Dank, das war es schon. Klasse :OK:
Worm
Beitrag von Worm »
Markus
Gesperrt
Zurück zu „Kneipengespräche“
