Tube amp , wich one? mein deutsch ist nicht so gut
robert1325
- Neuling
Hello,
I'm interested in buying a chinese tube amp, I don't know what a good match with my B&W dm603s3 is. I was looking at :
yarland pro 200 se
yarland pro 88 se
mingda 368 B
My B&W's are 90db / 8 ohm
I'm dutch so my german is not very good.
Ich bin interessiert, an, einen chinesischen rohre Amp zu kaufen, Ich weiß nicht, was ein gutes Gleiches mit meinem B&W dm603s3 ist. Ich betrachtete:
yarland Pro 200 se
yarland Pro88 se
mingda 368 B
Mein B&W ist 90db /8 ohm
Ich bin hollandisch, mein deutsch ist nicht so gut.
yarland pro 200 se
yarland pro 88 se
mingda 368 B
yarland Pro 200 se
yarland Pro88 se
mingda 368 B
Hello Robert,
what do you think about a good old french Jadis Orchestre modded by our old fellow Heijopo. It is a fantastic sounding device for less money. Contact him if you are interested.
cons
M;chael
EDIT Rightwriting
cons
M;chael
EDIT Rightwriting
Zuletzt geändert von Michael B am Di 29. Aug 2006, 21:57, insgesamt 1-mal geändert.
"Gewerblicher Teilnehmer"
- RG 9 Jünger
Hoi Robert,
thats the way it had to go.
Or think about a Unison S2 K.
its a very fine Italian Amp.
Gruß, Christian
- Tom_H
As for the Chinese products did you already consider the Cayin A88T? This is also a very good Amp, used by many people here in this forum.
It would be of help to know about your budget and the strengths and weaknesses of your system.
robert1325
- Neuling
I was looking to buy an amp at www.ornec.com, the cayin a88t is to expensive for me ( i'm a 17 year old student
I currently have :
cambridge audio 640 A amp
cambridge audio 640 C cdp
B&W dm603 s3 (90db 8 ohm) speakers
My father has two 300B audion mono blocks of 25 watts, with tubes that need replacement (old) . I love the sound , but find it lacking in Bass, low end.
I listen to all kinds of music ( rock jazz pop....) and would probably use it for movies to ( just 2.0) .
My budget will be around 600 / 800 euro's ( 600 if I keep my cambridge ampifier , and probably around 700/800 if I sell it)
I was thinking of an kt88 or kt90 tube amplifier , because they have more power and therefore would be more allround? suitable for more music and for movies to? I will use it in a small room ( 3x 4 m)
The yarland pro 200 se looks interesting but might be to weak. How does the yarland pro 88 se sound?
I just found this amplifier:
http://www.pacificvalve.us/XSD2020AKT8.html it is supposed to be nearly as good as the cayin a88t for a much lower price. i can get it on ebay for about 700 euro's including shipping and and VAT ( BTW) + customs.
http://www.timaudio.com/showphoto.asp?photoid=472
I currently have :
the Yarland Pro-200SE is definitely too weak for your B&W I guess. But it sounds just so wonderful !
Needs at least a speaker with 95 dB or even more, otherwise no fun ! Bass isn't weak at all, just kind of pulsating instead of "hammering" like solid state.
Why don't you try to build your own speakers, horns e.g. with 95 dB+
There are a lot of cheap tricks around in the net and than you might also consider the Pro-200SE again !
robert1325
- Neuling
robert1325
- Neuling
robert1325
- Neuling
Een 2ehands Primaluna Prologue One zou best een goede keuze zijn. En het is noch een Nederlandse versterker ook.
http://www.primaluna.nl
