Cayin SCD-50T
Cayin SCD-50T
Der Name ist Programm, der erste SACD-CDP von Cayin:
http://www.sparkaudio.com/cp02.asp?id=121
Und das sagt Babelfish
◆ SACD is the new generation of digital sound specification, has a higher analysis compared to traditional CD, the frequency sound and the dynamirange.
◆ the simulation audio frequency output used two sets of mutually independent electron tubes and the transistor adjusts the sound electric circuit, the transistor output circuit has selected the field effect tube which careful screening paired: The electron tube output circuit uses two Russia to produce the 6922EH tube, and uses 12AU7 to carry on the gallbladder rectification.
◆ the complete digital signal output, outputs coaxial, including the optical fiber outputs.
◆ uses the SONY machine core system, stirs up baldly is SONY KHM-280AAA. ◆ uses SONY Corporation based on DSD technical SACD special-purpose decoding chip CXD2753R.
◆ uses American BB Corporation 24Bit/192kHz electric current output DAC PCM1738 to carry on the D/A transformation.
◆ the I/V switching circuit uses the American BB Corporation high accuracy, is high 速运 puts OPA627.
◆ the low pass filter circuit uses the American BB Corporation low distortion audio frequency special-purpose to transport puts OPA2604.
◆ the analogous circuit and the digital circuit separately use the independent power transformer and the rectification constant voltage system supplies power.
◆ the use specially lowly leaks the magnetism, the high efficiency ring-like power transformer for this machine development.
◆ the VFD sound special-purpose lattice display monitor, the fashion modelling luxurious is natural, is advantageous for matches with the different brand acoustic equipment.
◆ uses the 2mm steel plate to purify the engine case, has the good anti-knocking property and the shield effect.
Zuletzt geändert von Erzkanzler am Mi 19. Okt 2005, 08:59, insgesamt 1-mal geändert.
SDJungle
Beitrag von SDJungle »
Sieht nicht unlecker aus, wobei ich allerdings sagen muß daß mein Musikgeschmack weitgehend SACD-inkompatibel ist - sprich ich finde kaum oder gar keine softe Ware in dem Format. So darbe ich halt weiter, mit meinem Thorens TCD 2000 sowie dem Sony DVP-NS900V und schiele leicht neidisch gen China... :lol:
hifiwilli
Beitrag von hifiwilli »
Hat denn schon jemand das Teil gehört.
Möchte mir einen SACD-Player anschaffen und haben den Shangling 200
ins Auge (oder besser ins Ohr) gefaßt. Welchen nehmen??
Warte mal gespannt auf erste Hörberichte...
mfg Jürgen
Wer Ohren hat, der höre!!
Der war nicht schlecht, Du gehörst zu den wenigen Menschen in Deutschland die schon mal ein Foto gesehen haben. Hören..... :roll:
Beim 17A haben wir ja auch den Betastest gemacht.
Mal sehen wo der Preis landet.
boarder
Beitrag von boarder »
Den hatten wir doch schonmal hier vorgestellt:
http://www.roehren-und-hoeren.de/phpBB/ ... .php?t=303
Komm mir doch nicht mit News von gestern :mrgreen:
Marcel
Nu sei nicht so hart mit ihm - er hat im Moment etwas viel Sand im Getriebe... :lips: :mrgreen:
Zuletzt geändert von 2285b am Do 24. Feb 2005, 18:37, insgesamt 1-mal geändert.
2285b hat geschrieben:Nu sei nicht so hart mit ihm - er hat im Moment etwas Sand im Getriebe... :lips: :mrgreen:
Dann wollen wir mal hoffen, dass ER ab nächster Woche wieder zu Sportwagenleistung aufläuft........... :wink:
Mal rein optisch gefällt mir der 17A besser...... :lips:
Hannes
Beitrag von Hannes »
also ich finde beide Klasse, und der 17 Klingt ja shcon mal sehr fein!!!
Das sollte dann bei dem Teil auch so kommen, wenn der dann noch normale CD's abspielt wie der 17er ist das este Wahl.
Hannes
:oops: Kam mir doch irgendwie bekannt vor.
Neu ist allerdings die Beschreibung auf der Spark-Homepage, die i.A. gerade mit allen Neuerscheinungen versehen wird.
P.S. Der mit dem SAND im Getriebe war nicht schlecht :wink:
Hi Hannes, noch auf? :lips:
Kann nicht jeder SACDP auch normale CDs abspielen?
Hannes
rrrrrh pfff rrrrhh
huch, was was?? Wer weckt mich denn da jetzt noch :lol: :lol:
Hannes
Nach der technischen Beschreibung nutzt der SACD den gleichen Filterkreis wie der 17A, die sollten klanglich also nicht so weit auseinanderliegen.
Nur das wieder die blöden OPA2604 eingebaut sind. :evil:
Nur das es keine Nachfragen gibt:
ICHLÖTEKEINEMEHR!
Löten die sich soo besch**** ?? :shock:
Und wie, SMD beidseitig. Das ist nichts mehr in meinem Alter, da hilft auch die Brille nicht mehr viel, nur noch eine grooooße Lupe.
Ui.... SMD beidseitig ist echt daneben :Chry:
Das würde ich wohl nur mit sehr viel :weed: in Angriff nehmen. Und das Ergebnis wäre dann wohl sehr zweifelhaft :cry2:
Ich glaube ich hab die Dinger aber schon irgendwo im Angebot gesehen, fertig gelötet.... hmmm... ich glaube bei feickert? Kann mich aber auch irren.
Gruß Thargor.
Schönes Teil.................. :oops:
Wenn das Ding nicht zu teuer ist, mache ich den Beta-tester! :oops:
War mir klar. :roll:
Mel*84 hat geschrieben:Wenn das Ding nicht zu teuer ist, mache ich den Beta-tester! :oops:
Thomas, versuch doch mal heraus zu finden, ob Du als Beta- Tester keine Sonderkonditionen bekommen kannst??? :wink:
Ich denke das würde die Gespräche mit Regierung und Bank doch ziemlich vereinfachen......... :shock:
Zurück zu „Röhren-CD-Player“
