Hello Thorens Lovers
Kleine Hilfe -Little Help
How old is my Thorens and what for a bearing I have ?
Wie alt ist meine Thorens und was Für ein Lager habe ich ?
1957 Introduction of the TD124 Hi-Fi record player.
1958-1961 Introduction of the models TD184, TD134 with BL104 tonearm, the TD135 and the BTD-12S tonearm.
1962 Introduction of the unique TD224 HI-Fi record changer. Based on the TD124 but with smaller spindle bearing and shaft, additional gears, pulleys and levers, this 'record changer' stored it's stack of 8 records away from the player so that only one LP rested on the platter at any one time.
The introduction of the TD121. A TD124 without strobe speed control. Marketed as a 'slightly' less expensive but high quality table. The introduction of the TD111.
1965 Introduction of the TD150 with TP13 tonearm.
1966 Effective July 1st, 1966, the Swiss Thorens-Franz AG took over the entire business concerning Thorens record players and together with EMT Wilhelm Franz of Germany, they established a new business for research, development and manufacturing in Lahr / Germany, located in the foothills of the Black Forest.
1968 Introduction of the TD125 (without startpulley) (Bronze sintered bushings 10 mm with nylatron Thrustplate)
1969 Introduction of the TD150 Mk II with new tonearm TP13A.(Bronze sintered bushings10 mm with nylatron Thrustplate)
1972 The introduction of the TD125 MkII. and TD 160 (Bronze sintered bushings10 mm with nylatron Thrustplate)
1974 Introduction of the TD126 "electronic" with tonearm TP16.(Bronze sintered bushings10 mm with nylatron Thrustplate)
1976 Introduction of the TD 126 MK I (Bronze sintered bushings10 mm with nylatron Thrustplate)
1975 Introduction of the TD 145 (Bronze sintered bushings10 mm with nylatron Thrustplate)
1977 Introduction of the TD 126 MK II (better Motor )(Bronze sintered bushings10 mm with nylatron Thrustplate)
1977 Introduction of the TD 126 III ( 7mm Bearing )(Bronze sintered bushings10 mm with nylatron Thrustplate or Brass pleas control)
1978 Introduction of the TD104, TD105, TD110, TD115.(Bronze sintered bushings 7,2 mm with nylatron Thrustplate)
1981-1983 Introduction of the TD226 (Bronze sintered bushings10 mm with nylatron Thrustplate)
Introduction of the TD127 (Bronze sintered bushings10 mm with nylatron Thrustplate)
1982 Introduction of the upgraded TD166 Mk II
Introduction of the TD146
Introduction of the TD147
Introduction of the TD 160 Super
Introduction of the TD 524
1983 The Thorens Prestige is introduced.
Introduction of TD 320 (Bronze Sintered Bearing)
Introduction of TD 318
Introduction of TD 316
1984 Introduction of TD Phantasie (Brass bearing 10 mm)
1985 1984 Introduction of TD 520 (brass bearing 10 mm + 1 Hardmetal Thrustplate for the version "S" with 8 Kg brass platter
1988 Introduction of TD 320 II (Brass bearing 10mm + 1 Hardmetal Thrustplate for the version "S" with 8 Kg brass platter
Introduction of the TD 146 V (brass bearing with Nylatron Thrusplate)
Introduction of TD Concrete (Brass bearing)
1989 Development and production of the TD2001 1990 TD300 (Brass bearing 10 mm with Harmetall Thrustplate)
1991 Introduction of the TD180 semi-automatic record player. (not im Lahr)
Introduction of the Ambiance (brass bearing with Hardmetal Thrusplate)
1992 Introduction of the TD 320 Mk III (brass bearing with Nylatron Thrusplate)
Introduction of the TD 146 MK VI (brass bearing with Nylatron Thrusplate)
Danach weiß ich davon nichts , kleine Urlaub ?
Introduction of the TD290 "Budget High-End" turntable. 1993 The production of the low-priced Thorens record players starts up in Lodz / Poland.
1995 Introduction of the TD 318 III (brass bearing with Nylatron Thrusplate)
1999 Introduction of the TD 325 and TD 190
ATTENTION: All brass bearing need the bearing oil Titan Super ( JB N° 1) and the other Bronze Sintered bearing Winn precision fluid N° 78 (JB N° 2 "s")
For TD 124 use Texaco= (JB N° 2).
Rgds
Joel
THORENS-HISTORY-BEARING-OIL
- Jürgen Heiliger
Hallo Joel,
inwieweit ist Dir Bekannt, dass es bei den USA-Modellen unterschiedliche Bezeichnungen zu Europa gab?
Bei der Durchsicht im Unergründlichen und einer Prospektsammlung aus den USA, die mir zukam, fiehl mir dieses auf.
Hier noch einige Ergänzungen zu Deinen Ausführungen......
ca. 1984 Thorens TD 126 MK III VCC (Joel hast Du da genauere Daten?)
ca. 1985 TD 126 MK IV (gleich dem TD 126 MK II bis auf den Tonarm TP 16 MK III)
ca. 1984 TD 226 VCC
1982 The Reference
der TD 127 besitzt den Motor des TD 126 MK II und dessen Elektronik.Introduction of the TD127 (Bronze sintered bushings10 mm with nylatron Thrustplate)
ca. 1984 TD 226 VCC
1982 The Reference
Hallo Juergen
Ich kenne Die TD nicht aus die Prospekt.
Prospekt Schreiber sind gar nicht nach gekommen alle Änderung mit zuschreiben, manche Tonarm haben ihre Bezeichnung sehr schnell geandert.
Der TD 126 MK IV oder Centenial, Jubilee oder Super Serie habe immer da gleich 10 mm mit gesintert Bronze Lagerbüchse bis auf die TD 320 MK II.
Dazu sind sehr viel Spezial Serie entstand wie Osawa, Schauland, Phonograph SE, Atr, Studio , Sonderwünsche...............
Die Sinterlager / Messing Lager sind bei Thorens /EMT alle gleich egal wo man sie geliefert habe Weltweit.
Ein einzig Ausnahme gibt es bei TD 160 MK II Da gibt es nicht zwei sinterlagerbuchse sonder nur ein verkurzt.
Messing Lager sind auch alle gleich bis auf die TD 2001 und 320 "S" .
Wenn jemand genau wissen will was er für ein Lager hatte ist sehr einfach.
Antriebsteller senkrecht hoch heben und nachschauen ob der Lager ein Öldepot hatte oder nicht.
Bei die version mit schwer Teller, TD 320,TD 126, und manche Blechgeräte Serie ist ein kontrolle notwendigt, weile bei dieser Version zwei variante gibt.
Dazu sollte man berücksichtigen ob man ein Stabilizer oder sonst Beschwerung dazu nutze.
Ein Wechsel mit ein andere Lageröl ist nötig um ein positive Ausgleich zu bewirken, besonder bei 7,2 mm Antriebsteller Achse.
Bei TD mit Gleichstrom Motor kann auch ein zu empfindlich Steuerung mit ein adequat Lageröl ein zusätlich dämpfung erreicht werde, aber bitte nich gleich das Sinterlageröl nehmen, es gibt daswischen noch genug Stufe.
Wer unsicher ist und optimal Lösung sucht kann ich wenn ich es weiss, gleich zwei Lageröl für den Falle geben so kommt man schnell ´das beste raus finden.
Das gilt auch für fremd Lager, wer mir die richtig Infos gibt über sein Lager kriege kein "Standard" lageröl sondern was am beste funtionniert.
Universal sowie Standard Lageröl gibt es bei Lager nicht, Der Lagerspalte, Lagerwand ,Lagerartzustand, die Pflege und viel ander Parameter zwingen ein adequat ÖL zu verwenden um die garantiert daten zu bewähren.
Es lohnt sich ! das ÖL bleibt ewig lang im Lager , wer mal ein Teller Achse ohne Öl mal lagert kann sich mal die Oberfläche anschauen, der Zeit wirkt ,Staube auch ! lasse der Deckel + Bodenplatte zu, das drehende Platte ist ein Staube Magnet, Staube ist auf dauer der grösste Feinde von Electronik und Motorlager und Tellerlager .
Joel
PS:VCC gibt es nicht es heisst VCM
Joel
